Configures the port information portion of the circuit ID.
| port_info | Specifies the circuit ID port information in the format of VLAN Info - Port Info; maximum length is 32 bytes. |
| port | Specifies the port for which DHCP Snooping should be enabled. |
The default value is the ASCII representation of the ingress port‘s SNMP ifIndex.
This command allows you to configure the port information portion of the circuit ID whose format is vlan_info - port_info for each port. The parameter port info is a string of up to 32 bytes in length. When a specific value is not configured for port information, the port_info defaults to the ASCII representation of the ingress ports‘s SNMP ifIndex.
This command was first available in ExtremeXOS 12.3.
